Mouse emulation help
LakersFan
Post by LakersFan »
I'm new to all this, but I can't seem to find a way to speed up the mouse movement. Additionally I'd like to reduce the acceleration stop factor to zero and have it start one speed and remain until the button is released. I found this thread (http://www.eventghost.org/forum/viewtopic.php?f=2&t=233) and tried adding the python script, but it doesn't seem to make a difference.
Anyone out there able to help me out?
Thank you!!
LakersFan
Re: Mouse emulation help
Post by LakersFan »
Well, I can change the speed okay. However I'd like to fix the issue of the acceleration stop factor. Basically I'd like it to stop when I let go of the button. Currently it keeps rolling a bit. Seems like it would be an easy fix.
This is the code I'm using:
eg.plugins.Mouse.plugin.thread.maxSpeed = 10
eg.plugins.Mouse.plugin.thread.accelerationFactor = 0.005
eg.plugins.Mouse.plugin.thread.accelerationStopFactor = 0.05
If I change the last option to 0 (zero), the mouse won't work at all.
