Hello
I'm trying to setup the plugin webserver but I can only get it to work with
localhost:8098
when I try to enter the computers static IP 192.168.0.1:8098 I get:
This page can't be displayed
ÔÇóMake sure the web address http://192.168.0.1:8098 is correct.
ÔÇóLook for the page with your search engine.
ÔÇóRefresh the page in a few minutes.
I have tried changing port.
As long as I type localhost:8098 it's working fine and it's showing index.html
What am I doing wrong ??
BR
Nisse
Web server only on localhost
Re: Web server only on localhost
Windows Firewall ???
Thank for reply
Sorry for the lack of information.
I'm using windows 7 and firewall is off.
My original goal is to be able to get events from a linux machine running openelec thats why I need to get webserver up and running.
BR
Nissse
BR
Nissse
Is the IP of your computer really 192.168.0.1, or is that maybe the address of your router?
Thank you for your reply.
My IP is 192.168.0.1 and I have the router at 192.168.0.50
ipconfig /all
I tried to disable ipv6 but same result.
Strange thing is when i ping localhost I get this:
And when I ping the name of the coputer (server1)
It look to me like it's a ipv6 reply but I get the same reply even if I disable ipv6 on the NIC.
Any ides ?
BR
Nissse
ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Server1
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 6C-F0-49-DF-47-E7
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f45d:686a:4746:e329%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.1(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.50
DHCPv6 IAID . . . . . . . . . . . : 242020425
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-FB-E1-21-6C-F0-49-DF-47-E
DNS Servers . . . . . . . . . . . : 192.168.0.50
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{7B477F22-6406-4641-91C9-FC0DF25EB3AB}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:3f:547:fa69:3e08(Prefer
ed)
Link-local IPv6 Address . . . . . : fe80::3f:547:fa69:3e08%12(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : DisabledStrange thing is when i ping localhost I get this:
C:\Users\User1>ping localhost
Pinging Server1 [::1] with 32 bytes of data:
Reply from ::1: time<1ms
Ping statistics for ::1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0msCode: Select all
C:\Users\User1>ping server1
Pinging Server1 [fe80::f45d:686a:4746:e329%10] with 32 bytes of data:
Reply from fe80::f45d:686a:4746:e329%10: time<1ms
Ping statistics for fe80::f45d:686a:4746:e329%10:
Minimum = 0ms, Maximum = 0ms, Average = 0msAny ides ?
BR
Nissse
I disabled the ipv6 completely using this guide http://support.microsoft.com/kb/929852
Now it looks better when i ping but still the same problem.
when i ping localhost I get reply from 127.0.0.1 as normal :
But trying 127.0.0.1:8098 in a webbrowser dont work.
Using localhost:8098 works as normal
I don't get it, very curios to hear the explanation for this one.
Pinging Server1 [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0msUsing localhost:8098 works as normal
First I will Thank krambriw and piert for trying to help out.
I downloaded this old version of webserver and replaced it in C:\Program Files (x86)\EventGhost\plugins\Webserver\__init__.py
Now it's working again. =)
viewtopic.php?f=9&t=1610
Glad you got it solved. Keep an eye on the announced webserver update by Pako on this forum. According to Pako, it will have some exciting new features.
