[Template] HTML/AJAX HTPC remote layouts for Webserver
therealbiglou
Post by therealbiglou »
I just wanted to share with you an HTML remote I built for controlling my HTPC and home audio. I've attached a zip that contains the necessary files. Simply unzip it to the directory of your choice and set the Webserver plugin to point to the root. Feel free to modify any and all of the files to your liking--I doubt anyone has my exact setup.
The html pages are built on the responsive Bootstrap framework. Because of this, the remotes will conform to your device's screen size. For instance, the "Living Room" remote layout will change from a horizontal layout (for desktops and laptops) to a vertical layout (for phones and tablets) based on the display's width. For example, here's what the two look like:
Image Image
The pages are also coded with AJAX so that the page is not refreshed after every button press. This is especially handy on mobile browsers which have terrible page load times. This makes jamming the volume buttons in rapid succession possible. For most of the buttons, I used an iconography font called Font-Awesome. All necessary files to make this work are included. A few of the buttons require .svg images which are also included.
I don't know if any of this will be of use to anyone, but I thought I might as well share what I've created. Enjoy! :D
EventghostHTMLRemote.zip
(260.04 KiB) Downloaded 438 times
Re: [Template] HTML/AJAX HTPC remote layouts for Webserver
This is for sure a very nice contribution to the community, thank you!!
Best, Walter
