Controlling my D-Box software
THX-UltraII
Post by THX-UltraII »
I own a D-Box motion system in my home theater (http://www.d-box.com). My D-Box seating is driven by a d-box decoder (external hardware box) that is connected to my PC. On my PC i run specific software that D-Box made. With this software I can control a few important things like the volume of the seating/motion etc.
D-Box recently added Added 'TCP/UDP commands support'. In this topic http://www.c4forums.com/viewtopic.php?pid=120684 you can read that there are no drivers available for this feature (I don t know why you would need drivers for this??). There is an application that I installed on my Android Phone called iRule which can control some basic things of the software that runs on my pc but not all things.
Is it possible that I somehow can control my D-Box software that is running on my PC with my Logitech HR in combination with Eventghost?
ps. the D-Box software also has keyboard shortcuts support but this does not work for me because I want/have to adjust things in the software while running a movie and that is not possible because I use Media Player Classic - Home Cinema with a renderer called madVR which gives 'exclusive mode''to my screen and the keyboard shortcuts only work when the D-Box software control panel is active, maximized AND on top.
I m also including a link to the .pdf that D-Box send me which I don t understand but maybe you guys do :)
http://www.sendspace.com/file/mljudd
