USB-UIRT Double Events
ijourneaux
Post by ijourneaux »
I ahv ebeen using a USB-UIRT for a few years under Win7 32bit. I have started to noitce that in EventGhost, I have started to experience double button presses from the USB-UIRT to EventGhost. The only solution is to reboot the computer. After the reboot USB-UIRT and EventGhost works normally for a few days before the problem reoccurs.
Has anyone encountered this behavior when you consistently get doulbe events in EventGhost? Any solutions? Is the USB-UIRT perhaps failing?
therealbiglou
Re: USB-UIRT Double Events
Post by therealbiglou »
Oddly, I get double events, but only with the Xbox 360. In WMC on my main HTPC, I get no such double events.
Unfortunately, I have no solution.
piert
Post by piert »
I have the USB-UIRT now for a couple of years, I guess. In the beginning I have had issues with it when it stopped working after a while because of an emitter that I had inserted into the USB-UIRT. This was being influenced by strong electromagnetic fields. Since I removed the additional emitter I have never had any problems anymore.
