Can I use EG to customize my Harmony MCE keys?
dannieboiz
Post by dannieboiz »
I'm not getting much support from Harmony so I have to see if there are any alternatives to make my system work.
My harmony is configured basically like these instructions in the link below. All is working but my back key isn't doing anything for me, using my keyboard the "backspace" button bring me back to my previous screen. Can I use event ghost to make this happen?
http://forums.logitech.com/t5/Harmony-R ... d-p/374844
kkl
Re: Can I use EG to customize my Harmony MCE keys?
Post by kkl »
Yes. You could try out just emulating (Action/Window/Emulate Keystrokes) the backspace key to make sure it does what you want. I'm assuming that the IR receiver, MCE, and EG will all be on the same PC.
