Counter
nikus_v13
Counter
Post by nikus_v13 »
Hi can you add a counter which counts event and responsa by event ? For exsample : counter 1# -> lg: counter1# 1... counter1# 2...3....10 (the counter counts forward and backward). Sorry for my weak english
Re: Counter
I unfortunately did not understand what you mean.
nikus_v13
Re: Counter
Post by nikus_v13 »
I mean counter count event ex: keyboard button pres and trigger curent macro at set number.
Re: Counter
Have you tried the Multitap plugin - specifically Single Key mode?
nikus_v13
Re: Counter
Post by nikus_v13 »
Hi yes i try to use it. I want to make something like this: https://www.youtube.com/watch?v=M_X-KrfMF-4
and use eventghost to count visitors. For exsample keyboard 1 then 2 counts as one next 1 then 2 count as 2 then3...4...5
but 2 then 1 counts backwards.
Re: Counter
nikus_v13 wrote:I want to make something like this: https://www.youtube.com/watch?v=M_X-KrfMF-4
Yes, now I finally understand.
In this case, we do not need a new feature.
Similar things you can do using EventGhost for many years.
This can be solved in different ways.
Here you see one of them (you may need to add the Webserver plugin to your configuration):
Here's a copy of that part of the tree (you can do copy / paste to tree):
<EventGhost Version="1640">
    <Folder Name="Counter - demo" Expanded="True">
        <Macro Name="Webserver: Increment persistent value: visitorCounter" Expanded="True">
            <Event Name="Main.VisitorPlus" />
                Webserver.GetPersistentValue(u'visitorCounter')
                EventGhost.PythonCommand(u'eg.result=str(int(eg.result)+1) if eg.result is not None else "1"')
                Webserver.SetPersistentValue(u'visitorCounter', u'{eg.result}')
                EventGhost.ShowOSD(u'{eg.result}', u'0;-48;0;0;0;700;0;0;0;0;3;2;1;66;Comic Sans MS', (255, 0, 0), (0, 0, 0), 1, (5, 5), 0, 0.0, True)
        <Macro Name="Webserver: Decrement persistent value: visitorCounter" Expanded="True">
            <Event Name="Main.VisitorMinus" />
                EventGhost.PythonCommand(u'eg.result=str(int(eg.result)-1) if eg.result is not None else "0"')
nikus_v13
Re: Counter
Post by nikus_v13 »
I can't use version 1640. Maybe you have another solution ?
Re: Counter
nikus_v13 wrote:I can't use version 1640. Maybe you have another solution ?
You can find several solutions. For example:
1) You can try to use the latest version of the Webserver plugin in your program version.
2) You can use global variables instead of persistent variables of Webserver plugin
nikus_v13
Re: Counter
Post by nikus_v13 »
OK I make a counter but what I have to do to eventghost respond to 1 and 0 fo ex send comand by winlirc plugin ?
Re: Counter
I'm sorry, but I do not understand your question.
What do you mean by "fo ex send comand"?
nikus_v13
Re: Counter
Post by nikus_v13 »
Sorry... for exsample send code I want to mak something to turn on or off the lights if some one enter or leaves a room I'v got almost entire house controled by eventghost and winlirc.
Re: Counter
I have a lack of information from you. I do not know your situation and I do not know how you can to control light using WinLIRC.
However, I understand that you need an event when the first visitor comes into the room and an event when the last visitor leaves.
So you can do such as the following:
1) Use Python Script actions instead of Python Command actions
Code for incrementation:
eg.globals.visitorCounter = 1 if not "visitorCounter" in eg.globals.__dict__  else eg.globals.visitorCounter + 1
if eg.globals.visitorCounter == 1:
    eg.TriggerEvent("Turn.On", prefix = "Light")
Code for decrementation:
eg.globals.visitorCounter = 0 if not "visitorCounter" in eg.globals.__dict__  else eg.globals.visitorCounter - 1
if eg.globals.visitorCounter == 0:
    eg.TriggerEvent("Turn.Off", prefix = "Light")
2) Then you get the necessary events:
nikus_v13
Re: Counter
Post by nikus_v13 »
I not working... Light is controled by winLIRC by ir codes
https://www.youtube.com/watch?v=TKNPElUFtpM one of the rooms
Re: Counter
It WORKS.
I tried it and then I used the copy / paste.
And BTW - next time please include FULL error message.
According to this piece, I can not say exactly where you made a mistake.
But it is certain that it is a problem indentation.
Find information about the Python indentation on the Internet !
One more note:
I have a feeling that you are behaving as when this is a paid support.
I see very little effort on your part (including writing posts here).
You're the one who wants to solve something and it seems that you spend less of your time than I do.
nikus_v13
Re: Counter
Post by nikus_v13 »
You are right it's working! I had got too many spaces when i copy/paste code. THANKS for your help !
