event ghost with pronto hex codes
user28
Post by user28 »
hi, i am new to Event ghost and i have read the documentation, it helps me and i have eHome Infra-red transceiver HP media centre modele no OVU400102/71.
and i using this device with Event Ghost to capture the Remote ir code. I am using Plugin Microsoft MCE Remote-Vista/win7 when i play my sony remote in front of the device the Event ghost shows me the following -:
MceRemote.SIRC15.2213
MceRemote.SIRC15.3203
MceRemote.SIRC15.3200
MceRemote.SIRC20.39D00
MceRemote.SIRC20.39D01
MceRemote.SIRC20.39D02
MceRemote.SIRC20.39D03
MceRemote.SIRC20.39D06
MceRemote.SIRC20.39D08
MceRemote.SIRC12.087D
MceRemote.SIRC12.068F
MceRemote.SIRC12.0092
MceRemote.SIRC15.485F
i have learned the Pronto hex code format from remotecentral.com , now is it possible to convert the above code to Pronto hex codes via any plugin ?
kkl
Re: event ghost with pronto hex codes
Post by kkl »
What you are seeing in the left pane are Events. These can be used to trigger Actions, but they don't contain the details of the IR signal.
To get Pronto codes, you need to Learn each remote button/code. To do this, Add Action...Microsoft MCE Remote - Vista/Win7...Transmit IR...OK...Learn an IR Code, then follow the directions.
I believe that the Sony Pronto hex codes are readily available elsewhere, so this won't be the fastest method to obtain them. I also have a vague recollection of reading that the Pronto codes through this plug-in aren't necessarily accurate. I haven't checked myself.
user28
Post by user28 »
thanks allot , now i am getting pronto hex code from Learn ir codes.
actually i am working on universal remote. so is there any tool or plugin in Event ghost which will convert that pronto hex code into .wav file , i have read the wave file structure from this link https://ccrma.stanford.edu/courses/422/ ... aveFormat/ l
I am stuck is because I have been unable to convert one pronto code to .wav file for any device I have, although I know my IR transmitter works as after hours of looking for LG .wav files I found a file called service-ok-ok.wav This file allows me to get into the service menu of my tv.... but this is all I can do as I do not know how to create a wav file.
my transmitter is just 2 IR LEDs on a 3.5mm audio jack and about my transmitter you can check in this link http://rtfms.com/episode-4-turn-your-ip ... m#comments
kkl
Post by kkl »
The JP1 folks are the experts on IR protocols and they have developed lots of neat tools. You might take a look at this page to get started.
user28
Post by user28 »
hi, i have sansui LCD and my remote model no is GEB01S
i have capture it's Pronto hex code of menu button it's giving below pronto code
0000 006E 0000 0024 0159 00AA 0017 0015 0017 003E 0017 0015 0017 0015 0017 0015 0017 0015 0017 0015 0017 0015 0017 0040 0017 0015 0017 0040 0017 0040 0017 003E 0017 0040 0017 0040 0017 003E 0017 0015 0017 0015 0017 0040 0017 003E 0017 0015 0017 0015 0017 0015 0017 0015 0017 003E 0017 0040 0017 0015 0017 0015 0017 003E 0017 0040 0017 0040 0017 003E 0017 05F1 0159 0055 0017 0E9C
i want to ask that is it giving me the right pronto or not ?
and when i click TEST button in front of my TV nothing happend ?
user28
Post by user28 »
any help on my previous post ?
