(virtual) serial port
THX-UltraII
Post by THX-UltraII »
I m using the Serial Port plugin from Eventghost. This all works perfect with my program called VSPE (Virtual Serial Port Emulator by Eterlogic).
When starting up windows Evenghost runs automatically. Also, I put a shortcut to VSPE in my startup folder. However, it does not work ok. This is because VSPE has to load FIRST and only after it has run Eventghost has to start. At this moment I think both are starting up at the same time or maybe even Eventghost starts running first. But the VSPE program has to load first.
Is there a way I can make the serial port plugin or Eventghost as a whole start running with a delay when widows starts up?
Re: (virtual) serial port
You could try this:
http://www.r2.com.au/
Actually, I think you can try this simple and free solution to delay EvenGhost to start plugins...
Best regards
