MCE IR Vista Plugin Update
abuttino
Post by abuttino »
I have had countless problems where I need to close EG from the Task Manager and when EG starts back up, the pipe usually isn't available..
To thwart that, I built an event into the plugin if the service is not running or the pipe isn't available..
Copy this macro into your EG configuration and use the python file attached instead of the one found in your MCEIR_VISTA plugins folder.
<EventGhost Version="1640">
    <Macro Name="Restart MCE IR">
        <Event Name="MCE_Vista.Pipe Not Available" />
        <Event Name="MCE_Vista.IR Service Not Running" />
            System.Execute(u'net', u'stop AlternateMceIrService', 3, True, 2, u'', False, False)
            System.Execute(u'net', u'start AlternateMceIrService', 3, False, 2, u'', False, False)
Figured I'd share this one..
(22.83 KiB) Downloaded 153 times
Luca Brasi
Re: MCE IR Vista Plugin Update
Post by Luca Brasi »
You're the man abuttino! Thanks!
This one had been buggin me fore years over and over again :-)
