I know this has been talked about before. I am curious if there is a way to have eventghost start a macro at a specific time of the day. I have lightout installed and can wake up computer at 3am after server downloads video files. I found the xbmc library update command in eventghost and I have that set up as a macro when I push yellow MCE button on my logitech harmony remote which works perfect. Through trial and error I have also got my harmony remote toggling back and forth between XBMC and WMC because I ran into issues with XBMC integration app for WMC on Windows 8.
Can someone please tell me how to setup a macros where at a certain time of the day I trigger XBMC library update?
Update XBMC Library with eventghost
Re: Update XBMC Library with eventghost
The timer plugin will do that.
