Action "Get Mute Status" on a microphone
Snowbird
Post by Snowbird »
Hello Everyone,
I have 2 problems that might be related, they both deal with the SoundCard.
Let me first tell you what I want to do before describing the problem. :)
I'm using a laptop that has a built-in speaker and a microphone, I use it a lot for audio conferencing everyday and obviously I need to mute the microphone many times during a conference (because of a parallel call phone for example, or many other reason that might arise during a conference). I don't have any LED indicator that tells me the microphone is muted or not, so I thought I could make my own indicator using the OSD feature of EG.
What I want is : I want to know the state of the microphone in a quick manner just by looking at my screen.
Problem #1 :
When I try to add the action "Get Mute Status" my SoundCard detects 3 Devices :
- Primary Sound Driver
- Speakers (Conexant 20585 SmartAudio HD)
- Internal Microphone (Conexant 20585 SmartAudio HD)
If I select any of them, they all give me the speaker state (muted or not muted), that means that when I select "Internal Microphone" it doesn't work, since it gives me the state of the speaker instead. This is very strange because EG is able to detect and list all the SoundCard devices correctly (speakers + microphone), but is unable to control the microphone status as expected... Does anyone know how to make this thing work ?
Problem #2 :
I observed this problem on a Desktop computer too (so it must be a general issue, not only with my laptop)
When I try to add the action "Set Master Volume" I get the following error right away ! and the action is not added of course.
10:06:42 Traceback (most recent call last) (1640):
10:06:42 File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 59, in ProcessingTask
10:06:42 self.Configure(*args, **kwargs)
10:06:42 File "C:\Program Files (x86)\EventGhost\eg\Classes\ConfigDialog.py", line 165, in Configure
10:06:42 treeItem.Configure(*args)
10:06:42 File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionItem.py", line 101, in Configure
10:06:42 return self.executable.Configure(*args)
10:06:42 File "C:\Program Files (x86)\EventGhost\plugins\System\__init__.py", line 1046, in Configure
10:06:42 deviceCtrl = panel.Choice(deviceId, SoundMixer.GetMixerDevices())
10:06:42 File "C:\Program Files (x86)\EventGhost\eg\Classes\ControlProviderMixin.py", line 58, in Choice
10:06:42 return eg.Choice(self, value, choices, *args, **kwargs)
10:06:42 File "C:\Program Files (x86)\EventGhost\eg\Classes\Choice.py", line 33, in __init__
10:06:42 self, parent, -1, pos, size, choices, *args, **kwargs
10:06:42 File "wx\_controls.pyc", line 494, in __init__
10:06:42 TypeError: Sequence of strings expected.
If I add the action "Change Master Volume", this one is added as expected and is ready to use without any issues.
I don't know if those 2 problems are related, but they both deal with the SoundCard, it looks like there is some reworking to do on this part.
Thank you in advance for any help you could provide.
Re: Action "Get Mute Status" on a microphone
Snowbird wrote:Problem #2 :
This looks like a bug that occurred when blackwind made ÔÇïÔÇïsome modifications:
viewtopic.php?f=5&t=4041
I already have a solution. Maybe tomorrow I will give it available.
Snowbird
Post by Snowbird »
Thanks Pako for your reply,
that's good news if you know how to fix Problem #2 :)
What about Problem #1 ? Do you have an idea of how to fix this ? I tried this in a python script but with no success :
eg.plugins.System.GetMute('Internal Microphone (Conexant 20585 SmartAudio HD)')
Thanks again for your time.
Snowbird wrote:What about Problem #1 ?
I tried to contact Blackwind if he could do fix, but he did not answer me yet.
Meanwhile, you can use the following file, where is fixed at least the second problem.
Plugin System
(67.76 KiB) Downloaded 301 times
Snowbird
Post by Snowbird »
Thanks Pako,
Problem #2 is solved !!! :)
The strange thing is that I have the same behavior as in my Problem #1, I can only set the volume of my speaker, not the microphone :)
whatever what I choose from those 3 devices, it controls only the speaker's volume. I really hope someone could fix this, I would really like to control the microphone status.
Many thanks again Pako ! :)
Snowbird
Post by Snowbird »
Pako wrote:I tried to contact Blackwind if he could do fix, but he did not answer me yet.
Hi Pako, did you get any news from Blackwind ?
No, unfortunately not.
As I found out, so even the PM is still in my forum Outbox.
This means, that he did not read it yet.
Snowbird
Post by Snowbird »
No.
blackwind
Post by blackwind »
It's been a few months since I've had access to my development box, and it'll be another month or two before I will again and can properly address this. In the meantime, try accessing your device via ID rather than string, like so:
eg.plugins.System.GetMute(1)
EDIT: Decided to give it a quick shot before leaving. This is largely untested, but may work.
SoundMixer.py
(15.65 KiB) Downloaded 241 times
/bw
Snowbird
Post by Snowbird »
Hi Blackwind,
thanks for your time !!
I tried both suggestions and none of them have worked, it simply doesn't give me the microphone state ! :(
If you have any other idea please let me know.
PS. Happy New Year to everyone ! :)
blackwind
Post by blackwind »
Which OS are you running, Snowbird? And did these macros work in r1610?
/bw
Snowbird
Post by Snowbird »
Hi Blackwind,
Thanks for your reply, I'm using Win 7 64bits on a Laptop and it didn't work on a previous version of EG, so it's not a "new" problem I guess, I'm sure it has been around for some time, maybe since always.
Let me know if you want me to do some tests, if I can help you in any way to solve my problem, I will do it.
blackwind
Post by blackwind »
Managed to reproduce and resolve it.
This should be fit for inclusion in the next build, Pako.
patch.zip
(62.11 KiB) Downloaded 263 times
/bw
Snowbird
Post by Snowbird »
THANK YOU !!! :)
I confirm, It's finally working !!
One last question, is there a way to fire an Event when the Microphone is muted / unmuted ? It's already possible to fire an event when the speaker sound is muted/unmuted, there might be a way to do the same thing for the microphone ?
As I was explaining in my very first post
The thing is now that the microphone state works, I have to check the state of the microphone every 1 second to display on the screen the actual state (probably with a loop, I don't know how to do that with EG). That's why I'm asking if there is a way to fire an event when the microphone is muted/unmuted, it would be much easier for me.
Again, a BIG thank you for both of you, Blackwind and Pako !!
