Startup errors
Re: Startup errors
It seems that the problem is in some action "Python Script":
09:42:03     File "C:\Program Files (x86)\EventGhost\plugins\EventGhost\PythonScript.py", line 71, in __init__
I do not have it available, so I can not help more.
Re: Startup errors
EventGhost is a built-in plugin.
Python Script is a part of it.
A in your configuration tree is (as is obvious) used some Python Script action.
But you still hiding it from us, so we can not help.
Re: Startup errors
phil wrote:is that useful?
No, I do not need this.
I'm the same.
But you have somewhere ACTION Python Script ...
Re: Startup errors
@phil,
To help analyzing your problem, please make a complete screen shot of you configuration tree fully expanded (the tree structure on the right side) and upload your xml file (you find the name of it in the window frame on top)
The actual xml file is in the eg working directory, this could vary depending on what windows version you are using. If you do "Save As" you will find the working directory where the xml file is stored.
Best regards
Re: Startup errors
should a disabled script be processed on startup?
It can be discussed but personally I think this is a good behavior. The same happens also for all plugins that you have in your system even if they are not used, the correctness of the code syntax will be checked at startup when the python source (.py) is compiled into byte code (.pyc).
The discipline you should have is to keep unfinished or faulty code belonging to scripts or plugins separated until they are done. This actually works out pretty well in the long run
BestR Walter
Re: Startup errors
I agree with Walter and I consider this behavior to be completely correct and desirable.
