After my previece post regarding a motion sensor that will be activated when I get home, now I want to install a simple USB numeric keypad in order to deactivate the system. For example when I get home I press on the numeric keypad 4 digit code and the system is deactivated and in this way the motion sensor will not send me emails.
I can trigger actions with keyboard events but only one press at a time or ALT+"any key" for exapmle "Keyboard.Numpad4". But how can I create an event that will wait for a 4 digit code?
Trigger action by a keyboard password code
Re: Trigger action by a keyboard password code
For example, using Multitap plugin.alonmalka wrote:But how can I create an event that will wait for a 4 digit code?
Great thanks!!
