Problem with launching application with EG
ekimneems
Post by ekimneems »
Hey all,
I'm trying to launch HyperSpin with EventGhost. When I launch HyperSpin from the Start Menu it works fine, but with EG it doesn't seem to be the active window. I have to hit alt+tab to get any keypresses to work.
So in my macro, I added a wait of 5s (just in case it hadn't started yet), did a Find Window (using drag and drop), and then Bring Window to Front. But it doesn't work. I checked the shortcut to HyperSpin on the start menu and there are no parameters or anything special that I can see. Any ideas? Thanks!
