emulate Fn (function) key
kmc
Post by kmc »
is there a way to emulate the Fn (function) key in EG? With the program KeyTweak I can retrieve a scan code for the key (57443). Not sure if this helps...
I want to use it to gradually dim the display, using Fn+End or Fn+Home on a Lenovo T420s Win7 Pro SP1 x64, EG 0.4.1.r1640
Thanks for your support!
kmc
Re: emulate Fn (function) key
Post by kmc »
anyone?
