XBOX One
sideone
XBOX One
Post by sideone »
i had used the xb 360 as a media center extender for about a day, and missed my remote. I do like the voice control of the xb though, so my topology has now changed. The WMC win 8.1 server is connected through the hdmi pass through connection. So far, a/v is working properly. I am able to watch movies, tv (using hdhomerun prime), and multiple applications without issue.
I use a rii flymouse remote with the IR portion of the remote passing through a usb-uirt device. The IR signal uses an extensive configuration within to control WMC, projector, wireless hdmi extender, nest, and a denon amp. I understand that the power cannot be controlled. However, i am unable to change channels with voice commands either. I had initially attempted to point the kinect at the usbuirt, but found a nonstop stream of IR data. Now, an ir receiver directly connected to the transmits to the the usb-uirt box to deliver its commands to EG. I issued the command ' watch starz (channel 419)' and found the following events in the log. Each time the ' watch startz' command had been issued, the event was different.
10:38:02 USB_UIRT.Unknown.1545
10:38:03 USB_UIRT.Unknown.11DD
10:38:04 USB_UIRT.Unknown.15551
10:38:04 USB_UIRT.Unknown.1D
10:38:05 USB_UIRT.Unknown.51
10:38:11 USB_UIRT.Unknown.501
10:38:11 USB_UIRT.Unknown.1555
10:38:18 USB_UIRT.Unknown.1555
10:38:19 USB_UIRT.Unknown.55
10:38:19 USB_UIRT.Unknown.15555
10:38:24 USB_UIRT.Unknown.154
10:38:24 USB_UIRT.Unknown.54
10:38:24 USB_UIRT.Unknown.1595
10:38:25 USB_UIRT.Unknown.155
10:38:26 USB_UIRT.Unknown.154
10:38:40 USB_UIRT.Unknown.1555
10:38:41 USB_UIRT.Unknown.1555
10:38:41 USB_UIRT.Unknown.5DD
10:38:42 USB_UIRT.Unknown.155
10:38:54 USB_UIRT.Unknown.155
10:38:54 USB_UIRT.Unknown.14
10:38:55 USB_UIRT.Unknown.1575
10:38:55 USB_UIRT.Unknown.151
10:38:56 USB_UIRT.Unknown.655
10:39:04 USB_UIRT.Unknown.154
10:39:05 USB_UIRT.Unknown.5155
10:39:05 USB_UIRT.Unknown.174
10:39:06 USB_UIRT.Unknown.55
10:39:06 USB_UIRT.Unknown.5755
10:39:06 USB_UIRT.Unknown.1455
I would love to use EG as my ir receiver for the , but how can i interpret the above commands? i would have thought the data would correspond to a channel number, but i do not see a trend. Should i look to another solution outside of EG to interpret those IR signals?
thanks,
