Control WiFi connection
I did a search for this answer and was shocked that it hadn't been asked before. I'd like to use eventGhost to dissconnect from one wifi network and connect to another. Is this possible? if not, is there any other program I can use to do this?
Re: Control WiFi connection
You can use eventghost for this, however there is not really an easy way to do this.
If you know what the ssid of the network(s) you are disconnecting and connecting to, you can use the netsh wlan commands just google "netsh wlan".
You can then use this: I did not test this, as I don't have a wlan on this pc. I used to use something similar on an older laptop (I just can't really remember the syntax).
