SSL implementation in EG
Dragon470
Post by Dragon470 »
I use ssl for the Nest Thermostat Plugin. My question is what version/form of ssl in implemented in EG?
print ssl.OPENSSL_VERSION is not available. Does this mean eg does not use a form of openssl, or if it does is there a way to update the module?
I ask this question as I am getting error
SSLError: [Errno 1] _ssl.c:480: error:0D0C50A1:asn1 encoding routines:ASN1_item_verify:unknown message digest algorithm
Even if this turns out to be a problem on Nest.inc end I would still like to know the status of the ssl implementation.
blackwind
Re: SSL implementation in EG
Post by blackwind »
ssl.OPENSSL_VERSION isn't available in Python 2.6.
Python's SSL module uses OpenSSL, but EventGhost isn't bundled with it. Presumably, it works with whichever copies of libeay32.dll and ssleay32.dll it finds in Windows\System32 (or Windows\SysWOW64). Updating these files may or may not help you.
/bw
