Recently I have created a small media browser 3 client, console utility which reads events from the Server and then runs an eventghost commmand line, for a member on mediabrowser3.com
Works great!... well kind of....
I seem to be having issues with my commmand line parameters.
Here is an image of the EventGhost set up:
I could post the entire VB.Net code here, but that would be pointless... I think.
the issue is I can't get the event to trigger from my commandline:
The code in the commandline I have so far is:
"{root to EventGhost Folder}\EventGhost.exe" -e SmartLinc: Screne Lights.On by the way I have the little app running as administator, which I found was causing issues at first.
Thank you a head of time. I have spent a long time on this already, it was supposed to take an hour, it has taken a couple days.
Ben
