Control Denon Receiver over TCP/IP
periam
Post by periam »
I wrote a simple plugin for controlling my Denon receiver over TCP/IP.
https://github.com/marneborn/eventghost-DenonTCPIP
The only things it does are:
  • Toggle mute.
    Raise/lower the volume
    - step increases if presses are fast enough, eg holding down the button.
    Set the input source.
izzy
Re: Control Denon Receiver over TCP/IP
Post by izzy »
Sorry, how do I get this to appear on EventGhost?
purp
Post by purp »
periam wrote:I wrote a simple plugin for controlling my Denon receiver over TCP/IP.
  • Toggle mute.
Is it possible to make it power on/off or change input?
