I use WMC exclusively for the Netflix plugin and have no issues using is. In my xml I have things defined like:
MceRemote.Mce.Up will trigger Emulate Keystrokes UP
MceRemote.Mce.Stop will trigger Emulate Keystrokes Shift+Ctrl+S
Again, this all works great.
Well, I am trying to use another plugin for WMC for Amazon Prime:
http://sharepointsnapple.com/amazonmceaddin/
The problem with this plugin is that it is coded to directly interpret the MCE commands to perform it's media player functions (stop/start/ff/etc).
Because I use EG with the MCE IR service, all codes get intercepted by EG and never make it on to the application.
The application is not coded with any keyboard shortcuts to control the app, either simply an on screen GUI (mouse control) or the direct remote codes.
The player is built in javascript and has a code section like the following:
function onRemoteEvent(keyID) {
switch (keyID) {
case 19:
//Pause
var mainPlayer = document.getElementById("objPlayerControlHost").Content.Bridge;
mainPlayer.Pause();
return false;
break;
case 250:
//Play
slControls.resumePlaybackFromLastPos(parseInt(slControls.currentSeconds));
return false;
break;
case 179:
//playPause
if (lastPress + 100 < new Date().getTime()) {
lastPress = new Date().getTime();
if (isPaused == 1) {
//Play
isPaused = 0;
else {
//Pause
isPaused = 1;
mainPlayer.Pause();
return false;
break
case 178:
//Stop
mainPlayer.Pause();
mainPlayer.Seek(slControls.currentSeconds);
window.external.MediaCenter.CloseApplication();
return false;
break;
case 166:
//Go back to main app
mainPlayer.Pause();
return false;
break;
case 177:
//Skip Back
mainPlayer.Seek(slControls.currentSeconds - 30);
break;
case 176:
//Skip Forward
mainPlayer.Seek(slControls.currentSeconds + 30);
break;
default:
//Ignore
As is, I can't find anyway to control this with my remote while having EG running.
Ideas?
