SageTV Events plugin
nightrader_
Post by nightrader_ »
I have attached the SageTVEvents plugin. This plugin uses the GetStatus plugin for SageTV to produce events for RecordStart, RecordStop, and NowPlaying.
This is the first Python code I have written, so please point out any bad code.
Any comments are welcomed.
Usage:
Add SageTVEvents Plugin.
Set address to IP of SageTV or SageTVClient which is running the GetStatus plugin.
Set port.
Set poll interval (note: set to 0 for manual polling using "Poll Server" action).
Select events to produce.
Updated:
0.0.1.8: fixed bugs added in .6 and .7
0.0.1.6: Changed config from "if" to "while"
ver 0.0.1.8
(17.1 KiB) Downloaded 184 times
ver 0.0.1.6
(16.92 KiB) Downloaded 162 times
CollinR
Re: SageTV Events plugin
Post by CollinR »
Gimme a minute to figure this out.
Is this dependent on a SageTV plugin? I would guess "GetStatus" plugin. However I cannot find one with that name.
This is what I know of:
Plugin: Status Monitor Interface by nielm
Plugin: LCD Smartie status display by AndersNolberger
Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) by cslatt
Utility: SageMCEDisplay -- LCD status display by Jere_Jones
Utility: SageTray - SageTV tray application by k10ck3r
Just post a link if you can. :D
nightrader_
CollinR wrote:Gimme a minute to figure this out.
Yes, It's the GetStatus part of the Status Monitor Interface (Nielm calls it GetStatus on his wiki page)
Once you have it running on your sage box, then install the SageTVEvents plugin into EG and set the IP and port. Then your EG should receive the events anytime the status changes.
Here is the link :http://tools.assembla.com/sageplugins/w ... in#preview
Hope that clears it up.
Post by Bitmonster »
Your Configure() method needs a little update ("while" instead of "if"). The __info__.py is also deprecated. You find the infos here
http://www.eventghost.org/forum/viewtopic.php?f=2&t=604
and here:
http://www.eventghost.org/wiki/Writing_Plugins
nightrader_
Bitmonster wrote:Your Configure() method needs a little update ("while" instead of "if"). The __info__.py is also deprecated. You find the infos here
and here:
OK, Thanks, I will make the changes when I get home from work tonight.
I'm guessing the rest of the code looked ok?
Thanks again. :D
Chuck Wagon
Post by Chuck Wagon »
I just found this plugin and I am trying to use it, but it isn't working for me. I created a folder called C:\Program Files (x86)\EventGhost\plugins\SageEvents and put the attached file in the folder. Next I created a new configuration and tried adding SageTVEvents Plugin. I accept all the defaults, but after clicking ok I get the following errors in the log and the plugin won't load:
Autostart
Main.OnInit
File "C:\Program Files (x86)\EventGhost\eg\Classes\ButtonRow.py", line 108, in OnOK
self.parent.OnOK(event)
File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 161, in OnOK
self.DispatchEvent(event, wx.ID_OK)
File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 122, in DispatchEvent
self.__processingChannel.send(wx.ID_OK)
TaskletExit
Am I doing something wrong?
