Remote Control Plugins
This topic is an adjunct of the Remote Controls topic.
Similarly, this topic may eventually have to be handed over to one of the admins to continue.
Thus, I will use ControlFreak to organize this topic until I surrender that profile to the admins.
So, for now, WharfRat is ControlFreak.
EventGhost 0.4.1.r1640
PHX01RN plugin v3.0.1
- ControlFreak
Re: Remote Control Plugins
Part I : Introduction
This topic is about the plugins for the remote controls.
It does not describe plugins for anything else, unless it is necessary.
The topic is structured as follows:
WharfRat
- ControlFreak
Part II : Explanation
The details for each remote control plugin follows a consistent format.
plugin code: the reference code for this plugin
included: is it included with the EventGhost installation program
We can, of course, adapt these details as the need arises.
- see Remote Controls Part III
this is the preferred way to refer to this plugin
- this corresponds with the name in the EventGhost Add Plugin... dialog
- some of these plugins can be customized, so it may not necessarily appear like this
- if the plugin is not included, then it must be downloaded and installed manually
- some of the plugins do not have a dedicated forum topic
- many of the remotes require WinUSB, which is discussed in Part V
some of the other requirements are usually included with the remote control installation software
some of the other requirements must be downloaded and installed separately
each remote control may also have additional hardware requirements
please refer to the remote control links for additional hardware requirements as well
Last edited by ControlFreak on Fri Jun 13, 2014 10:31 am, edited 2 times in total.
WharfRat
- ControlFreak
Part III : Remote Control Plugins
Plugins marked as (*) are not included with EventGhost (as of v0.4.1.r1640).
The non-included plugins must be downloaded and installed manually.
remote plugins:
RP-0001 ASUS PSR-2000
RP-0002 ATI Remote Wonder II (WinUSB)
RP-0003 auvisio VRC-1100 Ro
RP-0004 BT8x8 based remotes
RP-0005 Conceptronic CLLRCMCE
RP-0006 Cyberlink Universal Remote Control
RP-0007 Egon USB receiver (*)
RP-0008 ELV FS20 PCE
RP-0009 Generic HID
RP-0010 Hauppauge IR
RP-0011 Home Electronics Tira
RP-0012 IgorPlug-USB
RP-0013 Keene IR Anywhere
RP-0014 LIRC Client
RP-0015 Logitech UltraX Media Remote
RP-0016 Microsoft MCE Remote
RP-0017 Microsoft MCE Remote - Vista/Win7
RP-0018 Microsoft MCE Remote - Vista and newer (*)
RP-0019 PC Remote Controller
RP-0020 PHX01RN
RP-0021 PlayStation 3 Bluetooth Remote
RP-0022 Speed-Link SL-6399 Media Remote
RP-0023 Streamzap PC Remote
RP-0024 TechniSat USB IR Receiver
RP-0025 TechnoTrend IR Devices (BDA)
RP-0026 TechnoTrend USB IR Receiver
RP-0027 Terratec USB Receiver
RP-0028 UIR / Irman
RP-0029 UIRT2
RP-0030 USB-UIRT
RP-0031 X10 Remote
RP-0032 Xbox remote control
RP-0033 Y.A.R.D.
non-remote device plugins:
RP-0034 Keyboard
RP-0035 Joystick
RP-0036 Sidewinder Game Voice
RP-0037 MouseEvent (*)
RP-0041 LeapMotionGhost (*)
Android device plugins:
RP-0038 terRemote (*)
Apple iOS device plugins:
RP-0039 EventPhone Remote
Windows Phone device plugins:
RP-0040 RemoteGhost (*)
non-catalogued plugins:
..-.... Desktop Remote
..-.... Webserver
..-.... voice control (*)
remote plugins:
RP-0009 Generic HID
RP-0014 LIRC Client
RP-0020 PHX01RN
RP-0028 UIR / Irman
RP-0029 UIRT2
RP-0030 USB-UIRT
RP-0031 X10 Remote
RP-0033 Y.A.R.D.
RP-0034 Keyboard
RP-0035 Joystick
..-.... Webserver
Last edited by ControlFreak on Fri Aug 15, 2014 12:08 pm, edited 2 times in total.
WharfRat
- ControlFreak
- ControlFreak
Part V : WinUSB
Some of the USB remote control plugins for EventGhost v0.4.x and later require WinUSB.
If WinUSB is needed, EventGhost will check to see if it has already been installed.
EventGhost can automatically download WinUSB if the computer is connected to the Internet.
One advantage of this method is that it will only download the required version: 32bit or 64bit.
Another advantage is that the downloaded files are automatically installed in the correct folder.
The disadvantage of this method is that the computer must be connected to the Internet.
WinUSB can also be downloaded from the EventGhost website and installed manually on each computer.
One advantage of this method is that the computer does not have to be connected to the Internet.
Another advantage is that you get the 32bit and the 64bit versions at the same time.
The disadvantage is that you have to copy the files to the correct folders manually.
It is a good idea to download WinUSB and keep a copy of it with your copies of the EventGhost installation programs.
The 32bit and the 64bit versions are approximately 5MB each, so the combined version is about 10MB.
To check if the WinUSB drivers have been installed on a computer, perform Procedure 02.
If your computer is connected to the Internet, it is simpler to allow EventGhost to install WinUSB automatically.
If you are installing WinUSB on a computer that does not have an Internet connection, then you must install WinUSB manually.
To install WinUSB manually, perform Procedure 03.
WharfRat
- ControlFreak
plugin code: RP-0001
remotes:
0001
included: yes
forum:
requirements: WinUSB
notes:
remotes:
0001
included: yes
forum:
notes:
WharfRat
- ControlFreak
plugin code: RP-0002
name: ATI Remote Wonder II (WinUSB)
remotes:
0004
included: yes
forum: Plugin Support ATI Remote Wonder II
notes:
remotes:
0004
included: yes
notes:
Last edited by ControlFreak on Mon Jun 16, 2014 11:42 am, edited 2 times in total.
WharfRat
- ControlFreak
plugin code: RP-0003
name: auvisio VRC-1100 Ro
remotes:
0005
0006
0007
0008
included: yes
forum:
notes:
remotes:
0005
0006
0007
0008
included: yes
forum:
notes:
WharfRat
- ControlFreak
plugin code: RP-0004
name: BT8x8 based remotes
remotes:
0009
included: yes
forum:
requirements: Dscaler
notes: the Vendor ID and Product ID may need to be modified in __init__.py of the BT8x8 plugin folder for some devices
remotes:
0009
included: yes
forum:
WharfRat
- ControlFreak
plugin code: RP-0005
remotes:
0010
included: yes
forum:
notes:
remotes:
0010
included: yes
forum:
notes:
WharfRat
- ControlFreak
plugin code: RP-0006
name: Cyberlink Universal Remote Control
remotes:
0011
0012
0013
included: yes
forum:
notes:
remotes:
0011
0012
0013
included: yes
forum:
notes:
WharfRat
- ControlFreak
plugin code: RP-0007
name: Egon USB receiver
remotes:
included: no
forum:
requirements: (WinUSB ?)
notes:
remotes:
included: no
forum:
notes:
WharfRat
- ControlFreak
plugin code: RP-0008
name: ELV FS20 PCE
remotes:
0015
included: yes
forum: Plugin Support ELV FS20 PCE
notes:
name: ELV FS20 PCE
remotes:
0015
included: yes
notes:
Last edited by ControlFreak on Mon Jun 16, 2014 11:43 am, edited 2 times in total.
WharfRat
- ControlFreak
plugin code: RP-0009
remotes:
0017
included: yes
forum: Plugin Support Generic HID
requirements:
notes:
remotes:
0017
included: yes
requirements:
notes:
Last edited by ControlFreak on Mon Jun 16, 2014 11:44 am, edited 2 times in total.
WharfRat
