EventGhost Error
micnda
EventGhost Error
Post by micnda »
Hi, I hope someone can help me with this. My event ghost is generating a log error(which doesn't seem to affect performance, but is very annoying). I get the following error in my log file.
File "EventGhost.pyw", line 51, in <module>
import eg
File "C:\Program Files (x86)\EventGhost\eg\__init__.py", line 28, in <module>
import Cli
File "C:\Program Files (x86)\EventGhost\eg\Cli.py", line 76, in <module>
eventstring = argvIter.next()
StopIteration
It seems to be caused when a macro (I've created to update XBMC) is triggered by ScheduleGhost. If I trigger the same macro manually I don't get this error message. And regardless of the fact that I get this error, the macro seems to preform as expected. None of the files listed in the error have anything to do with the ScheduleGhost plug-in as far as I can tell, but I can't make the error show up any other way.
Any help would be appreciated.
Plugins :
Directory Watcher
XBMC2
Growl
ScheduleGhost
Keyboard
Re: EventGhost Error
It appears, that some external program is trying to trigger an event in EventGhost using a command line.
In that command line is probably a mistake. More I can not say (I do not see that line).
