As title says.
Everything works fine, but when I try muting sound on my Windows 8.1 x64 with Realtek HD Audio, EventGhost crashes. I have lateset EventGhost 0.4.1.r1669 installed.
Unmuting and changing volume level works perfectly.
Any solution?
Muting sound crashes EventGhost
wojtek1986
Re: Muting sound crashes EventGhost
I've similar problem since 0.4.1.r1630 version on my Win7 64-bit. Changing system volume does not work anyway and muting crashes EventGhost, but changing media players volume (e. g. Winamp) works fine.
My solution at the moment is: using an older version:
http://www.eventghost.org/downloads/Eve ... _Setup.exe
I (maybe) found the cause.
Try to put the attached file __init__.py into the directory ...\EventGhost\plugins\System (instead of the original file).
Note:
It is intended for the version number r1669.
Note:
- __init__.py
- (68.42 KiB) Downloaded 201 times
wojtek1986
Unfortunately, changing system volume does not work with your plug-in. Muting does not work too, but pressing mute key does not cause, that Eventghost crashes.Pako wrote:I (maybe) found the cause.
Note:
I've forgotten to tell, that i use X10 remote control (Medion). Maybe it has some importance...
