I am still working on my system and am planning a new computer for htpc use. I plan to get the OrigenAE S16t case (I know the lcd is a bit overkill, but the htpc is connected to a projector, and I don't really have room to put a monitor near the pc. I had the case before, but it could damaged in shipping, and I really liked the case), which comes with this module for ir:
http://www.origenae.co.kr/en/accessory_ir310.htm
Does this module work with Eventghost?
Can other remotes be used (I suspect this may be more a WinLIRC question...)?
J├Ârg
functionality with OrigenAE IR310 (iMon)
Re: functionality with OrigenAE IR310 (iMon)
I found some reference that it is also MCE compatible.
J├Ârg
J├Ârg
