Hello !
I have some problems with the network recive/sender stuff. When i assign an key to an event that sends a network message to another computer the another computer see the data but dosen┬┤t trigger the event sent instead i get TCP.test ['172.30.0.193', 'withoutRelease'] if i add this to the event as a trigger, the event executes but as i understand it should trigger the event TCP.test ? by default, am i right also i can┬┤t get the -n command line option to work if i write
Eventghost -n 172.30.0.193 Tcp.test
nothing comes up in the other end, all firewalls are disabled and it works if i do it from the gui apart from the TCP.test ['172.30.0.193', 'withoutRelease'] thing. Any help would be very appriciated.
//F
Please help with network sender/reciver
Re: Please help with network sender/reciver
You MUST use a password, or at least mine never worked right without one.
EventGhost.exe -n 192.168.1.2:1234 4567 NightMode
EventGhost.exe -n {Host}:{Port} {Password} {Eventname}
You'll get it and find this is really an awesome feature!
