I keep getting this error when using the Media Monkey plugin. I am sending a message via AutoRemote. I am not sure if there is a fix for this or a work around. I know I had done it before, I think I did it using the System >> Start Application. I was just wondering if there was a way to fix the errors I am getting, as it would be awesome to use the plugin and the other features. It does work with the chrome fall back, but sometimes I forget to keep chrome open.
Exception happened during processing of request from ('::1', 52706, 0, 0)
File "SocketServer.pyc", line 558, in process_request_thread
File "SocketServer.pyc", line 320, in finish_request
File "SocketServer.pyc", line 615, in __init__
File "BaseHTTPServer.pyc", line 329, in handle
File "BaseHTTPServer.pyc", line 312, in handle_one_request
File "socket.pyc", line 406, in readline
error: [Errno 10054] An existing connection was forcibly closed by the remote host
Errors using AutoRemote and the MediaMonkey plugin
internaltheory79
