Emulate events from SpaceMouse
RobFR
Post by RobFR »
Hi all,
I just discovered EventGhost and it's quite amazing ! My goal is to emulate the events of the spacemouse from 3DConnexion. (the real spacemouse is on client side and the emulated one on the server).
I saw lot of EG plugins and I was wondering if someone had already worked on it (nothing in the archives..)? If no I ask you, as experimented users, if it's just possible.
Another constraints is that the spacemouse isn't directly connected on server. It's more a HID question but, program can listen to a device not plugged ?
I try to send EG keyboards event while my physical keyboard wasn't plugged. It worked well but may be those events are standards events .
Anyway, any kind of help would be welcome. Thanks,
Rob
