[FIXED] Error when selecting About
fidoboy
Post by fidoboy »
When you select Help >> About EventGhost... there is an error (it shows in red in log panel) Tested with 0.3.6.1262 version
regards,
Re: Error when selecting About
Post by Bitmonster »
You have missed to install the latest Setup.exe, I guess.
fidoboy
Re: [FIXED] Error when selecting About
Post by fidoboy »
You are right. I've installed latest setup.exe and then the update and now it works fine :wink:
regards,
