Install easy_install package?
bruinlax
Post by bruinlax »
I'm thinking about making a plugin that runs of Flask, which along with its dependencies is generally installed using easy_install for windows.
if i don't want to run off source, and use the built in py.exe / environment, is there a way to install / compile the packages?
Other than that the only way i can think would be to run all of eventghost off source, or have just the plugin start up on its own virtualenv.
bruinlax
Re: Install easy_install package?
Post by bruinlax »
So i think i got it running, but by doing it in a very hacky way
I did a virtualenv of 2.6.5 stackless, then easy_install flask.
then I copied the eggs into the plugin folder i'm writing and put this in the plugin __init__
import sys
sys.path.append('flask-0.10.1-py2.6.egg')
sys.path.append('itsdangerous-0.24-py2.6.egg')
sys.path.append('jinja2-2.7.3-py2.6.egg')
sys.path.append('markupsafe-0.23-py2.6-win32.egg')
sys.path.append('werkzeug-0.9.6-py2.6.egg')
it seems to work, but is there a cleaner way to install packages like that?
