Autoscript press Function Keys with pause between
kirmusic
Post by kirmusic »
hello to all,
i┬┤m a newbie and need your help
we run a program where we can switch the internal windows- screens within this SW with CTRL 1-9
in other words if i press CTRL 2 the window change to screen 2 if i press CTRL 3 it change to screen 3 aso.
i need a script where this working automatically with PAUSE between for example:
Press CTRL 1 -->PAUSE 60 sec --> Press CTRL 2 --> PAUSE 50 sec --> Press CTRL 7 ---> PAUSE 40 sec
and after going back to the beginning
Anybody there who can help me to get this done ?
will be really great !
Ewald
thanks a lot in advance
Re: Autoscript press Function Keys with pause between
Maybe this is the easiest solution:
kirmusic
Post by kirmusic »
hello pako
great and many thanks for this fast reaction
can you send me this script file you made to use it as a dummy for a first test ?
will be nice :-)
thanks in advance
Ewald
kirmusic wrote:can you send me this script file you made to use it as a dummy for a first test ?
I do not know what script you have in mind.
I used no script.
But maybe you have in mind a copy of the example.
It is here:
<EventGhost Version="1669">
    <Folder Name="Cycle" Expanded="True">
        <Macro Name="Emulate Keystrokes: {Ctrl+Numpad1}" Expanded="True">
            <Event Name="Main.RunCycle" />
            <Event Name="Main.Ctrl-1" />
                Window.SendKeys(u'{Ctrl+Numpad1}', False)
                EventGhost.TriggerEvent(u'Ctrl-2', 60.0)
        <Macro Name="Emulate Keystrokes: {Ctrl+Numpad2}" Expanded="True">
            <Event Name="Main.Ctrl-2" />
                Window.SendKeys(u'{Ctrl+Numpad2}', False)
                EventGhost.TriggerEvent(u'Ctrl-7', 50.0)
        <Macro Name="Emulate Keystrokes: {Ctrl+Numpad7}" Expanded="True">
            <Event Name="Main.Ctrl-7" />
                Window.SendKeys(u'{Ctrl+Numpad7}', False)
                EventGhost.TriggerEvent(u'Ctrl-1', 40.0)
kirmusic
Post by kirmusic »
hi pako
that works great !
many thanks !!!
one more question, lets say 2 :-)
1. can i isolate this configuration to only a independent software, i mean that this keystroke swaps getting only activated within a single program and not within all software where i move over with my mouse
2. how i can stop this configuration without to shutdown the eventghost SW ?
will be great to hear you soon
thanks in advance
Ewald
kirmusic wrote:1. can i isolate this configuration to only a independent software, i mean that this keystroke swaps getting only activated within a single program and not within all software where i move over with my mouse
If the action "Find a window" precedes action "Emulate keystrokes",
then emulated keystrokes should only be directed to the window, which had previously been found.
kirmusic wrote:2. how i can stop this configuration without to shutdown the eventghost SW ?
There are more possibilities.
For example, you can disable an entire folder or some macro.
