File Operations Crashes EG
Phil
Post by Phil »
Hi
Quite frequently when I try and use anything using the file operations plugin eg hangs.
This is on two different systems, one with windows 8.1 one with windows 2012
Any idea why?
thanks
Phil
Re: File Operations Crashes EG
1. This plugin has many years no changes and no problem is known. I need more information from you. For example xml file (preferably the most simplified) could help. Attach errorlog also (you can run the program with the -debug option or use the Log redirector plugin) and detailed description of the problem.
2. Similar posts do not belong to this part of the forum. The "Plugin Support" section is designed for it. You can find the most appropriate topic as follows:
