IF THEN ELSE with Actions
m19brandon
Post by m19brandon »
Hello, how can I do IF THEN ELSE with actions. I have a bunch of python script actions that I do this in and use "eg.plugins.*" command to execute actions but this makes the macros less visible and I was trying to avoids Jumps as this gets mess and makes it hard to copy and past other macros to reuse. Example.
<EventGhost Version="1640">
<Macro Name="IP2IR: Family Set to DVD (Computer)" id="485" Expanded="True">
EventGhost.PythonCommand(u'eg.result = None')
EventGhost.PythonCommand(u'if eg.globals.bl1_status == False: eg.result = False')
EventGhost.PythonCommand(u'print eg.result')
EventGhost.NewJumpIf(XmlIdLink(536), 1, True)
EventGhost.NewJumpIf(XmlIdLink(363), 2, True)
EventGhost.NewJumpIf(XmlIdLink(406), 0, True)
EventGhost.NewJumpIf(XmlIdLink(414), 0, True)
Thanks in advance, B
Re: IF THEN ELSE with Actions
m19brandon wrote:Hello, how can I do IF THEN ELSE with actions.
Use the "EventGhost\Jump" action.
m19brandon
That is want I'm doing now also but I want to stay in the same Marco.
m19brandon wrote:That is want I'm doing now also but I want to stay in the same Marco.
I don't think that's possible without using a Python script.
Why do you need to stay in the same macro? If you group macros in a folder it's almost like a single macro. :twisted:
m19brandon
Yes, I could do that :) Thanks, :D :D
I added a new action Jump with "Else" option to new EventGhost release.
This should facilitate the design that you need.
m19brandon
You are the man.
