Hi all.
I'm hoping to have EventGhost trigger a DOS command contained in the clipboard.
The process is Tasker > AutoRemote > EventGhost > DOS.
I've searched the boards and mucked about with things like Windows Command: "{eg.event.payload.armessage}" but I'm not a coder. I'm hoping this is a simple solution with a few lines of code but using trial and error to stumble upon a solution when there's a wealth of knowledge and experience available lies somewhere between stupid and moronic.
Thanks in advance.
Q
Hopefully a simple one.
Blindly fumbling in search of a solution.
Re: Hopefully a simple one.
To start, try reviewing this thread.
Hi KKL,
I looked at that thread. That's where the inspiration came from to try variations of the eg.event.payload.armessage came from. It looks like it's the same that Joao has on his site: http://joaoapps.com/autoremote/eventgho ... nd-tricks/
Unfortunately none of the combinations I tried worked. If I've missed something (probably blindingly obvious to those who code), please let me know.
Q
Q
eventghost.net
Be there or be square.
