How do I set a specific file opening as an event?
Syyiailea
Post by Syyiailea »
So I'm new to the program, and thought you guys might be able to help me out with this. What I want to do is, for example, whenever I open a file, say "Random Text File.txt" that it would register my opening that file as an event in EG, which I could then use to active macros. Any ideas on how I would accomplish this?
zian
Re: How do I set a specific file opening as an event?
Post by zian »
open file
look at log
drag task to tree
easy peasy
eventghost.net
Be there or be square.
Syyiailea
Post by Syyiailea »
zian wrote:open file
look at log
drag task to tree
easy peasy
But when I open the file, there's no record of it in the log. Again, I'm new, but as I understand it, the only things recorded in the log are the things you have plugins for. So is there a plugin to detect when files open?
zian
Post by zian »
check show log check file check box.
or uncheck
eventghost.net
jitterjames
Post by jitterjames »
You need to enable the "directory watcher" plugin first.
Syyiailea
Post by Syyiailea »
jitterjames wrote:You need to enable the "directory watcher" plugin first.
