Need help automating therenamer when movie files are present
xdmitri
Post by xdmitri »
Short question: Can someone help me with a python script so that when the directorywatched.updated becomes a .mkv or similar file, therenamer would start working, and if there isn't .mkv there yet it halts.
Long question: Even though there are many many posts about automating this process, mine happens to be different. Instead of using torrents, I download all tv shows from ftps, unfortunately manually. When this download is complete I have AutoUnpacker unrar the files in the directory and delete the rars. At this point I manually start therenamer that puts all the finished shows into the proper folder for xbmc to update. Since I don't know python, I have been stuck at getting therenamer to start properly when .mkv is ready to go for renaming. If anyone by chance automated downloading shows thru ftp, please do share, but thats less important.
xdmitri
Re: Need help automating therenamer when movie files are pre
Post by xdmitri »
Hey, thanks for your reply.
I have stumbled upon this page before, it is very good guide indeed. If I follow this path, it would run therenamer everytime the directory will update, which is after each rar file is downloaded, thats quite a lot of unnecessary fetch commands to take up the processor. It will of course eventually after each rar file is downloaded and finally unpacked stumble upon the .mkv file and rename it but I don't think its the right way to do this. Is there another option to filter video files?
