Are multiple selections allowed in EG? For example, if I press shift, it doesn't let me select more than one item. Similarly, holding down control doesn't let me arbitrarily select items that I want to manipulate (e.g. delete, move, etc.)
Is there any way to multiple select items in EG? If not, would this be implementable?
Multiple selections in EG.
Re: Multiple selections in EG.
How do you have your tree layed out?
All in one big folder or many folders?
Moving the folders works well, also I have started to do a bunch of that in the XML config using dreamweaver.
In many folders. The problem is not moving individual folders, but selecting more than one items/folders/etc. It would also make the interface a lot easier to use.CollinR wrote:How do you have your tree layed out?
