IÔÇÖve got a USB-UIRT on order so I thought IÔÇÖd install EventGhost while I was waiting for it to arrive. During the install I got this error:
The specified module could not be found.
LoadLibrary(pythondll) failed
IÔÇÖm installing on a Toshiba laptop running Vista Premium, 2 GB of ram. Does anybody know what the cause of this error is? How will I get rid of it and complete the installation?
Thanks for the help.
Installation problem
Re: Installation problem
Which file have you downloaded and installed?
Beta: EventGhost 0.3.6 build 1174 Setup.exe Dated 20 November
Have you tried another "EventGhost_0.3.6_build_xxxx_Setup.exe" ?
At first I thought you tried to install an Update which is a common mistake resulting in all kinds of errors.
I finally was able to get it working. I completely removed the original installation including the directory. I then downloaded the application again (same build) and installed it. Not sure quite why but everything seems to work the second time, now I've just got to do some playing around to see how it works.
Thanks for your help.
