Hello all,
I have been having a problem with plug ins dying, they just stop working. It has happened with the USB-UIRT plugin as well as the System plugin. The solution is to restart EventGhost and/or disable/enable the USB-UIRT in the device manager. Also, I am using the SageTV plugin and it has not had any problems.
It happens pretty randomly as well, I am using the latest beta version as of the posting.
