EventGhost locking up when BlueIris calls it
seandudley
Post by seandudley »
I am trying to use EventGhost with the PushBullet plugin to send a push when a camera detects motion in the BlueIris software. I seem to have hit a snag, though. BlueIris has to call the batch file that calls EventGhost with the command line parameters to send the PushBullet, but if BlueIris calls the batch file, EventGhost locks up. if I bring up the Task Manager and force close EventGhost, the batch file continues. If I run the batch file without BlueIris calling it, even with BlueIris running on the system, everything works fine. Anyone have any idea how it is that because BlueIris is the one that runs the batch file (which runs fine until it gets to calling EventGhost), it causes it to lock up? My system is Windows 8.1 64-bit.
If any developers would like to try and figure it out, BlueIris can be downloaded free of charge (evaluation copy you can use for 20 days without registering) at http://blueirissoftware.com/download/ .
Thanks.
Re: EventGhost locking up when BlueIris calls it
This problem can be caused by different Windows user accounts.
Are you sure that both programs (BlueIris and EventGhost) are running on the same accounts? Maybe one of them is running as Administrator?
Just a thought, maybe it's something else.
