need to restart EV every time MPC closes
virtual736
Post by virtual736 »
HI All, i cant figure this out, please help. I have windows 8.1.
If MPC-HC does not get closed, all is working fine.
If i close MPC-HC and then start it again, then eventghost does not execute commands to MPC, even though i see them being received in EV console.
Need to restart EV, and all works again.
Any ideas? please?
Re: need to restart EV every time MPC closes
Important information is missing.
What version EventGhost you have?
virtual736
Apologies, EventGhost version 0.4.1.r1700, MPC-HC ver 1.7.6 (tried other versions of MPC as well)
Many thanks,
In this case, it is difficult to help here, because for me, it works seamlessly with (almost) the same conditions. And I use it almost daily.
I can not repair the thing that works. And I can not see into your computer.
Note:
This setting is very important for proper function.
