EventGhost task from command line, error codes available?
seandudley
Post by seandudley »
I am using EventGhost to send some PushBullet .JPG files to my phone in the event that motion is detected on one of my security cameras while I am away. I am wondering if there are any error codes written to a variable or something that I can intercept in a batch file to re-try the send if there was a problem?
Thanks.
Re: EventGhost task from command line, error codes available
Maybe this plugin will help you.
