Questions about compatible receiver
mparadiso
Post by mparadiso »
I have interest in buying the Amulet remote control for use with EventGhost but I will need a MCE IR receiver.
2 receptors found on the internet and would like to take the course if they are compatible with the amulet.
http://pt.aliexpress.com/item/NEW-Comin ... dVersion=1
http://pt.aliexpress.com/item/new-for-H ... dVersion=1
You know let me know if any of those would work with the Amulet?
Thanks You.
WharfRat
Re: Questions about compatible receiver
Post by WharfRat »
Hello mparadiso...
Sorry about the late reply, I have been busy with some plugin documentation, and I was also a little ill recently.
I am not familiar with the Amulet remote control, but the two receivers from the Internet are familiar.
You might want to look at the Remote Controls topic first.
The receivers are:
0034 PC Remote
0018 HP TRC3
The 0034 is NOT a MCE remote, but 0018 (the HP) is. If you have not purchased anything yet, the HP is a very good choice.
Cheers, WharfRat
EventGhost 0.4.1.r1640
PHX01RN plugin v3.0.1
