http://www.rwe-smarthome.de
With this plugin you can integrate the RWE SmartHome Center into EG.
You can manipulate:
- AlarmDevices
ActuatorDevice
GenericDevice
RollerShutter
Any non boolean events will supply a payload which can be evaluated with:
Macro: EventGhost: Python Command
eg.result = (float(eg.event.payload) > float(45.0))Code: Select all
import datetime
#print eg.event.string,': ',eg.event.payload
def UniCoder(*a):
r=u''
for u in a: r += u if type(u).__name__=='unicode' else unicode(u)
return r
if not eg.event.payload is None:
with open("RWE_SHC_log.csv", "a") as f:
f.write( UniCoder( datetime.datetime.now().strftime("%Y-%m-%d %H:%M"),'\t',
eg.event.suffix,'\t',
eg.event.payload,'\n'
).encode('iso-8859-1')
)Macro: EventGhost: Jump To speed up Switching of groups you can combine/collect several Actions into one command by issuing MultipleCollect/MultipleCommit pair.
Have Fun
