need some help with a MCE remote
yarin
Post by yarin »
hi,
I'm using a mce remote with eventghost for xbmc.
I recently had to disconnect my pc from power. after connecting it again my mce remote stopped working. when i opened eventghost and then the .xml file i had no 'log' window or a 'configuration' window. i uninstalled and downloaded a newer version - 0.4.1.r1700. that solved the first problem. had the 'log' and 'configuration' windows but the remote didn't log any actions. i then found this post - http://www.eventghost.org/forum/viewtop ... &start=450 and the one in the link - viewtopic.php?f=9&t=1838&start=45#p22340. i downloaded the added 'temp.txt' file and followed the instruction. now the remote workes except for a couple of features that now work with windows media center.
how do i disable the windows media center and leave only the configuration tree that i wrote for eventghost?
