Sending keystrokes on German (Swiss) kbd send wrong chars
PaulSinnema
Post by PaulSinnema »
I've run into a problem with the 'Emulate Keystrokes' plugin. It seems that the Keyboard-Layout is interfering with the strokes being sent. I've created a Macro using the 'Emulate Keystrokes' like this:
{Shift+Tabulator}{Shift+Tabulator}{Shift+Tabulator}{Shift+Tabulator}{Shift+Tabulator}c:\Uniface7Export.trx
It should go to a certain Field in a Window and enter the ExportFilename like c:\Uniface7Export.trx'.
The {Shift+Tabulator} work fine but the text in the Field is wrong:
c:UNIFACE/EXPORT:TRX
If I change the Keyboard-Layout to Englisch-International the following is entered in the Field:
cèàUNIFACE/EXPORT:TRX
What I notice from the above is that changing the Keyboard Layout has influence and also that all the Letters are translated to Uppercase.
Anyone got a clue?
Paul
PaulSinnema
Re: Sending keystrokes on German (Swiss) kbd send wrong chars
Knock, knock, ...........
