InterVideo remote
_kuba_
InterVideo remote
Post by _kuba_ »
I got an IR receiver and remote called InterVideo rc-201. The problem is that it installs as a HID keyboard and HID mouse device. I have no other drivers that work. Can it be used with EventGhost? For now it just sends simple keystrokes like up, down, enter, alt-f4.. what I'm trying to achieve is to make it send custom/raw events, not keystrokes.
Bartman
Re: InterVideo remote
Post by Bartman »
If it just installs a mouse and keyboard you would have to use DirectInput.
_kuba_
Post by _kuba_ »
I can't seem to find any option or plugin for DirectInput in Eventghost. What exactly should I do?
