DenonIP Plugin
bassteq
DenonIP Plugin
Post by bassteq »
Using the latest version of event ghost, im trying to setuop this plugin https://github.com/marneborn/eventghost ... DenonTCPIP
But Im getting some errors below, appreciate any assistance. Thanks
Error while loading plugin-file C:\Program Files (x86)\EventGhost\plugins\DenonIP.
Traceback (most recent call last) (1700):
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginModuleInfo.py", line 70, in __init__
    __import__(moduleName, None, None, [''])
  File "C:\Program Files (x86)\EventGhost\plugins\DenonIP\__init__.py", line 4
    <!DOCTYPE html>
SyntaxError: invalid syntax
    <!DOCTYPE html>
Re: DenonIP Plugin
As it says, you have syntax errors in the file. You have to copy/download it again, open in a text editor and check the syntax so that it is ok
bassteq
Re: DenonIP Plugin
Post by bassteq »
Thanks will do!
